The next you would un-screw the dandi switch cover .... sorry don't know its actual part name
@spectra help here, kia kehte hein is cover ko
(thanks)
You have to carefully take out the front housing of the meter if you are not going to detach the steering wheel. In my case, i have put on an N16 one and it was also fixed with efforts so I decided not to detach the wheel. Another issue which you might face is when you once detach the wheel you have to then re-adjust it once more with the alignment guy. The caution necessary to take that cover with care is that it will get stuck with your dashboard border and may scratch it or damage it, so be very careful while taking it out.
Out without any damage after some effort, Alhamdolillah....
