I once posted about changing tire tire pressure sensors, and need to write in the new tire data in car computer(ECU), and that one requires measuring tire height manually.
Now I will introduce another way that fully automatic, the car is Chrysler 2009 Journey.
First turn ignition ON, and go into Body Control Module-->program tire size using diagnostic tool, I’m using Topdon Artimini.
This step is mainly to update tire circumference data, and device will auto read out the current tire circumference data is 2115mm. Then it will list all available tires for this car model, choose the one you are installing now, and all is done.
