hi guys i have xli 2005 and want to replace its brakes with abs. i require technical opinion in this regard.thanks
here, no one suggest you to do this thing
It is do able..but it need many things to be changed and the cost involve is around 30K . if you really wanna go for it i will tell you the person in rawalpindi .
regards
zeeshan change brake distribution T with that of a corolla Xbraking will improve alot
true,no point getting abs if ur brake distribution isnt proper
aoa every onesame is the case with me 2006,2.odwant to improve brakes,does that Tof X corrola will work?
+1 we have changed in our uncle's car and braking has been improved alot. no more skidding etc
Xli is notorious for it's bad braking issue and i'm surprised why Indus motors have not been bale to fix this very problem.
no braking issue in current Xli, the poster is talking about 2005 model ^^
Can it be done?
thanks. kindly tell address of that. what about exchange of brakes with X model
thanks a lot !can u tell me, that how much it costs
Dont do this.
Non genines may deceive your life.
change the T distributor as hash4u said! brakes will become better!
can you pls post the pic of this T distribution coz im having the same issue too..Pics will elaborate the same exact part..plus do also post the pic of T distribution of corolla x
https://www.pakwheels.com/forums/wheels-tyres-suspension-brakes-steering/162379-servo-brakes-xli-2006-athis will help!
and this is the pic of brake distributor if i am not wrong:http://www.google.com.pk/imgres?q=brake+T+distributor&um=1&hl=en&biw=1024&bih=605&tbm=isch&tbnid=rUiTXCt5PgIqbM:&imgrefurl=http://www.pistonheads.com/gassing/topic.asp%3Fh%3D12%26f%3D34%26t%3D768357%26nmt%3D&docid=E_MGWBFxsQu00M&imgurl=http://i34.tinypic.com/do9n5t.jpg&w=479&h=638&ei=rO8XT6L9NaXe4QTztqTcDQ&zoom=1
yes it is possible to do that but I will suggest u to go for GLI 06 instead
brakes are same in all corolla xli,gli,2.0D,se saloon (2002-2008)!
i suggest dont do this
then whats recomended??
