Thank you so much! I had my car checked in Islamabad electronically by car fest and Nazir Autos - just to find out that it was mechanically perfect with NO WORK required at all!!! While the ustad said "the engine has blow" - the experts said it's normal disel engine blow and a perfect soundless engine!! The whistle sound which the ustaad referred to as "Turbo dying due to engine blow" - was a whistle installed in silencer to make a beautiful sound on raving.
I cannot thank you enough and that discussion on D4D engines that you referred! I was advised to have the engine "overhauled" by two so called "ustaaads"- and would've ended ruining my engine for nothing!
I have changed the CL transmission oil (Toyota genuine was recommended by Pearl Lube and went with it). I have changed the coolant, oil and oil filter and air filter. Previously delo 400 was being used. I have used that for now and as advised by pearl lube - will change that in 2000 km and shift to deli gold 15w40. And will stick to that afterwards. Engine has done 130k. Is that correct advice? The engine is not reducing oil at all - I checked at 400. I asked pearl lube if I can shift from mineral to illy synthetic and he said since engine is not consuming oil it is safe and healthier for engine to make the shift. Kindly advise on this.
One last thing - the Vigo doesn't have a heater installed. All I have been told so far is that they an install a heater but I will have to take to the mechanic to shift between heater and AC; as only one will work at one time. So in summer I take the car to him and he turns off heater and turns AC on. And I do the same in winter - and he switches the heater on instead. Is there no option where both can work simultaneous and I don't need to visit the mechanic repeatedly???
