You have to be sure which car it is in the first place, I suggest you get some pictures first. In case it is a Dodge then you must keep in mind that parts will be hard and very expensive to source, and it would require a lot of patience and first hand research, as Reezvan has mentioned in his post earlier. Fiats and Austins are relatively easier to restore because of their simpler engineering. This car that you are mentioning will be quiet a task. If you feel up to it then I think you should not wait, however, once again please get the pictures first and put it up to the experts on these forums.
p.s please look into the part we talked about. Thanks
