Collecting starter spacer,some wires (I dont remember from where I removed)and nuts/bolts of bulkhead which are thrown in the battery tray for ages..
Ignition coil removed...This is the one I collected from" Bury" (UK) while I was roaming in a scrapyard (favourite place to visit) and found it in the engine bay of a mini which was lying there...
And windscreen washer system is the next..Removing electric pump......
Detaching pipes....
And windscreen washer pump/bottle out of the car...
i wish you have TV SHOW Spitfire:p(Y)
Heater pipes next...note the bad condition of clutch master cylinder...fluid has seeped through the slave cylinder and its all covered with salt sort of thing ...seized I supposed (did not check).
@rocklee....lolzzz
I am asking to remove the heater valve as well along with the pipes...
On the way noticed this bracket of windscreen washer bottle and asked to remove it too...
Bracket removed and screw going back to its hole.....
Bracket of Ignition coil also removed at this point....
Heater valve and Ignition coil bracket were fitted with the same bolts.....So it was remover automatically..
heater valve removed along with other pipe going to inner radiator...
control wire coming from fascia panel is being removed too..
And heater valve out of the car.....
Salamz Pakwheel brothers,Some more dismantling.......Next item is windscreen wiper motor...
Speed rod in action to remove bolts...
And wiper motor removed.....This snake like structure which you see in the following pic is the drive wire which is flexible and have a spring all over its length....It goes through a pipe and moves back and forth when wipers are turned on and this wire rotates wiper spindles which in turn move wipers arms.....
nice going.....this one would be a master piece with lot of experience from the previous one.
covering the flexible wiper motor wire in news papers and plastics because it is covered with grease and dust is expected to collect on it..
@saadisb...This will be a straight forward restoration as far as body is concerned but mechanicals/engine and suspension/steering will be in need of work....because I do not know in which condition its mechanicals are...never driven this car.only used as specimen to restore blue one...
