Clutch Master cylinder is next....speed Rod in action again.
Bolts removed.....6 of them.
And master cylinder with bracket coming out of the car...
Did not open the pipe which attaches it to the slave cylinder.Slave cylinder was already removed and tied up with a string... and it was stuck in the car..
trying to push it out of the car......
Master and slave cylinders attached with a pipe....
Seized master cylinder of clutch...
Leaking slave cylinder....
Firewall looking cleaner after the removal of some stuff....
Things removed from the car so far.....
Another view....
And Spitfire in sad state...
Front almost done,,,now came to rear side...
Rest of the boot/floor is fine except this nasty weld at underside of the boot floor...some previous owner......@#$%&)&*^.... $%%^&....welded silencer bracket with boot floor....also tried to raise the vehicle by placing jack at the rear edge of boot floor resulting in a bad bend...
Decided to remove rear pumper first...
some inspection of the bolt.......
Two bolts on the sides and two at the back.....
bolt is right besides the wire....
Removing right side bolt....
love the detail explanation, hats off to u sir.
And dropped....
