Indeed it is, here is the list of mechanical stuff that is needed to be done.
- Fuel filler pipe fitting
- Fuel ventilation pipe fitting
- Oil bath air cleaner fitting
- Fan shroud air pipes fitting
- Lower bottom shield fitting
- Raising the rear-end (even both side out correctly)
- Fixing the shifting issue
- Fixing the accelerator pedal so that it doesn't fall back
Honestly Nasir bahi, I don't want to switch workshops now. The nearest workshop near the current workshop is at least a 30 minute drive away and the distance from my place to the current workshop is almost 30 minutes as well.
I will have to travel for an hour to reach if I switch workshops now. Their isn't much mechanical stuff left to do. I just want to get it done as soon as possible and hand it over for the paint-job.
The thing is their isn't much work left. I have papers coming up as well so I won't be able to give much time to Blue. However, once the car is all done I will do the regular maintenance myself.
That is very true, you know for sure because you have dealt with these people in the past.
I most certainly am. But not right after the restoration, later onwards.
Custom exhaust, custom headers and maybe in the near future dual carburetors.
