Review - United Trail DT 125cc
Bike: United Trail DT 125cc
Market Price: 95k
Model: 2016
Category: Dual Purpose Trail
Engine: 125cc Single Cylinder 4 Stoke Air Cooled
MAX Torque (N.m/r/min): 11.0/5500
MAX Power (Km/r/min): 9.3/8000
Gears: 5 (All Forward)
Battery: 12V 7 AH
Seat Capacity: 2 Person
Starting System: Self & Kick
Max Speed = 100km/h
Break Front/Back = Drum
Rim Size: Front - 21 Rear ? 18
Weight: 120 kg
Best Average Till Now = 35km/Lit
NOTE: This bike is copy of Qingqi DP 150cc, Only Engine has been downgraded to 125cc rest each nut bolt is of the same bike. All reviews shared after Testing.
Major Changes:
Ignition Switch Key
Engine
Gear Shifting: All Forward
Engine Performance:
As above mention that it is the copy of the Qingqi DP 150cc so body weight is also same for 125cc engine. Comparatively 125cc engine of other Street bikes available in market it is low powered. (Power in sense of initial Pick), Even are high RPM at low gears, its output torque is very less which will give tough time on higher altitude. Trails demand higher power in the initial because when you do off road you are in low gears for quickly passing all trains of mud, rocks, water & heights.
On Straight Road:
Shifting of gear is smooth but if you give higher rpm in 2 or 3 complete bike will vibrate. Which is not an issue as chines don?t put balancer shaft in small engine to control vibration.
On Higher Altitude:
Carburetor need to be changed as bike start missing which we faced same issue with DP 150cc. (Use can use Carburetor of Delux 2006 Model)
Electric Part Issue:
As the quality of CDI is not good so better to change with Cg 125 (Grips need Replacement if you use Original one of Honda but if you want to put the same then, Search for Chinese brand)
Tyres:
Dual purpose Tyres, with very good thread will help you in Off Road-Mud & Rocks.
Things Need Attention:
Tuning is must from Expert - Other thing which need to recheck (Carburetor, Taped Adjustment, Oil Checking, Front Shock Oil Change & Setting, Break Leather Checking, Column Alignment, Chain Replacement with good brand, Complete body Inspection, Tight up all the nuts & bolts).
Over All Review:
Very Good Height, Self & kick both options are available. Light weight, easy handing, Round light with good focus on road. Not satisfy with the engine power.
