to check if the car is okay. start it up get it to normal running temperature which will take about 5 mints i guess.
after engine is fully hot which is the normal running temperature.
pull the hand break hard.
after that put it in to reverse, because engine puts more power in it and it gives a better feel for the car.
turn the ac on while the car is in reverse and turn all the lights on with high beams.
the more the car vibrates it is more likely to have problems later.
two of my friends have vits and both vibrate a lot and even when u turn the ac on the rpm drop a lot and engine goes in to stall mode.
i think its a very overpriced car instead you can get a brand new swift with most of the bells and whistles.
there is no substitute for a new car and when jdms get problems people in lahore atleast dont know ****.
