Hi guys i have beautiful car baleno 2004 brand new condition i very satisfied with her Royalness . as summer arives i went to hill areas came back chnge oil im using 20 w 50 its was 3.5 litter complete on changing Then on new oil it was driven only 1800 i change oil on very 2500 half litter was missing from engine chamber On next one quarter was missing on 1650 driven only no smoke nothing at all engine is smooth i drive on 40 80Please guide me a solution
Use some other oil in shell or caltex. Than change pcv valve of your car.
Thnx i will use guard 20 t50 w what you say ?
Sorry shell or caltex sure i will do it in morning . then on next 1600 km we will discuss
@umairfayyaz get hold of ZIC X5 20/50. this is synthetic blend. i have changed the same in my cultus EFi (same engine as Baleno) and i confirm you that it is an excellent oil - it has increased my cng efficiency alot. get hold of original ZIC - go to METRO to buy one
Hi every one after using 3 brands of oil zic pso shell 20/50 i come to conclusion to install ring only car is now at workshop head is send out to overall to head specialist and we are putting oversize ring in the car to get better comparison headrepair + oversize ring +headgaskit + timing belt + new plug hope issue will be reslove .i bhought this car used ring was already install so we have use now over size ring.
I have seen this literally hundreds of times, The problem is worn valve seals and/or worn valve guides. The piston and ring stack is almost never a problem unless you were running with no PCV valve, ghee as oil and no thermostat forever.
my mechanic asked to use 20/50 oil and after 500 ring running car is fine soundless engine.New issue arrive compressor is making heavy noise its unbearable what should i do orginal compresser
compressor change hoga..you in Khi?
also, share the price breakup of head work you mentioned above.
compresser ba ring was chaneg new gas install new pully instal total charges 3000
i will post here all price
