Salaam
Up for sale are Rocket Dry Batteries 150 A hr (Global batteries Co .Ltd) For UPS, Solar panels and Wind generator.
Global batteries Co .Ltd is one of the top notch battery manufacturer and their batteries are widely used for UPS and solar power systems and are known for their quality product. We have been directly importing these batteries mainly from Korea .These batteries are brand new and boxed packed. The design float life is 12 years at 20℃ (68℉).
ES Series AGM
The most advanced technology of Rocket, Valve Regulated Lead Acid batteries makes them highly useful in a brand range of application. Absorptive Glass Mat separators are used in these batteries. The use of high-purity calcium alloy maximizes the longevity of ROCKET batteries. So you will be assured with ROCKET batteries excellent performance in any circumstances.
ES Series high rate are specially designed to provide better cyclic life and are ideally suited for areas prone to frequent power failures.
The unique construction coupled with the use of special sealing epoxies and long sealing paths of ROCKET series ensures that no electrolyte leakage can occur from terminals or cases of any ROCKET Batteries. This feature ensures safe & efficient operation of ROCKET batteries in any position.
ROCKET Batteries have excellent Deep Discharge Recovery and Charge Acceptance even after deep or prolonged discharge.
MAIN APPLICATIONS
UPS
Telecommunication Equipment
Fire Alarm & Security Systems
Medical Instruments
Emergency Lighting
Computer Backup
Solar Powered Systems.
TECHNICAL FEATURES
Non-Spillable Sealed Construction
Absorptive Glass Mat System (AGM System)
ABS (Acrylonitrile Butadiene Styrene) container and cover
Gas Recombination
Maintenance-Free Operation
Low Pressure Venting System
Heavy - Duty Grids
Low Self-Discharge - Long Shelf Life
Wide Operating Temperature Range
High Recovery Capability
DESIGN LIFE
ES Series Designed for life of 10 years at an ambient temperature of 20 C / 68 F
These batteries can be used for UPS, Solar charging bank, and wind energy or for any other charge storage purpose. These are maintenance free lead acid batteries so they don't require extra care like liquid batteries. These batteries are AGM batteries so they provide an expected life of 8-12 years.
Main applications
- Telecom standby and cyclical applications
- UPS
- Power plant and power transfer system
- Solar energy system
- Emergency lighting system
Following are the specification of these batteries
Condition: Brand New
Origin: Korea
Item Description: Rocket Dry Batteries 150 Ahr (ES150-12)
Nominal Voltage: 12V
Capacity: 100Ampere/hour
Dimensions: 520 x 269 x 203mm
Weight: 50kg
Max charging Current: 37.5
Terminals: Terminal connector to screw M10
Mode of Delivery: delivery to anywhere in Pakistan on buyer?s expense.
These batteries can be load tested before you purchase them in order to insure the proper working condition .We deliver our batteries to any place in Pakistan .
Here at Hitech powers ,we are dealing in wide range of Dry Gel and AGM series Batteries and Solar panels also. If you need any other information about these batteries then please feel free to contact us.
0336-8214800
Abdul Samad
