Rockford Fosgate P325.1 mono amplifier !
Contact: 0344-4255560
Shipping on buyer's expense/risk
Amplifier Specs and details :
P325.1
If space is limited in your vehicle but you don’t want to sacrifice performance, the P325.1 is the amplifier for you. Its small footprint allows it to go where other amplifiers can’t, and gives you the PUNCH you’re looking for.
Technologies:
1.Balanced Differential Inputs
Differential inputs eliminate noise picked up by signal cables.
2.NOMAD
NOMAD is a "real time" analog computer that protects your amplifier from shorting speaker wires and...
3.MEHSA
Rockford Fosgate amps use MEHSA, a thermal substrate that maximizes heat transfer between MOSFET...
4.TRANS•ana
Trans•ana is a Class A/B topology that simplifies the signal path of the amplifier allowing...
Specifications:
Number of Channels: 1
Rated Power
(RMS Continuous Power): 175 Watts x 1 @ 4-Ohm
325 Watts x 1 @ 2-Ohm
Frequency Response: 20Hz to 20kHz +/- 0.5 dB
Crossover Controls: High-Pass (HP): 40-400Hz 12dB/octave Butterworth
Low-Pass (LP): 40-400Hz 12dB/octave Butterworth
Tone Controls: Bass: 0dB to +18dB @ 45Hz
Power Wire Gauge: 4 AWG
Heat Sink Type: Cast aluminum
Speaker Wire Gauge: 8 AWG to 18 AWG
Cooling: Convection
Visual Indicators: Power On
Signal Level
Thermal Status
Speaker protection
Circuit Topology Class: Class A/B
Shipping Weight: 11.5 Lbs.
(5.2 Kg.)
Dimensions (H x W x D): 2.1 x 11 x 11.7 (in)
5.3 x 27.9 x 29.7 (cm)
for more details and the owner's manual click on this link:
http://www.rockfordfosgate.com/products/details/p325.1
