[h=2]Mmats SQ4160[/h][INDENT]
True Class AB Amp which i wanted for this install, its an old school classic USA amp which features a high performance output topology as esoteric home equipment.
Toshiba Audio Grade Outputs
High Current Connectors
Independent Gain Controls
24db varriable crossover
SPECIFICATIONS
POWER @ 13.8 Volts:
RMS @ 4 ohms stereo 4 X 160
RMS @ 2 ohms stereo 4 X 175
RMS @ 4 ohms mono 2 X 350
Idle Current: 1.5 amps
Signal to Noise Ratio A-Wtd: <100dB
Total Harmonic Distortion: 0.04%
Channel Separation: <80dB
Input Sensitivity: 150mV-5V
Slew Rate: 15V/Usec
Fuse Rating: 60 amp
Dimensions:
Height: 2.25”
Width: 11.375”
Length: 19.375
General Information:
Frequency Response: <10Hz to 22KHz
Lowpass Filter: Variable 24db, 60 to 360Hz
Crossover: Lp / Hp / Off
Battery Connetors: 4 Gauge
Speaker Connectors: 8 Gauge
[/INDENT]
