When press clutch rpm goes up or down . When release it come to normal. But this happened while driving only. On idle its stable when press clutch no fluctuate in rpm.
City?
Car civic 99
Bhai you should get the car scanned and check the throttle position sensor and the Idle Air Control Sensor!
Ok sure will do that.Do resetting ecu will work.
if the sensor is faulty resetting will not work! Scan the car you will know exactly what is wrong?
ok will scan it and then see what it shows.
get throttle body service get tps iavc adjusted. but it getting low to zero all suddenly when driving ,like when you press race pedal its goes down they go up sometime
Like if you press clutch when driving the rpm goes to almost zero and then come back up few seconds later?
If this is happening then it is the iacv sticking and you should get it cleaned
Somme time goes zero and most of the time it rise even when standing and pressss clutch..Should replace iacv as already clean it 3 to 4 time and some adjustment made but same things
