Next 911-based RUF - the RGT-8 - due in 2011 with all-new 542bhp V8.
Almost 10 years ago to the day, RUF began to fill niches in the market with the, at that time new, water-cooled Porsche models. The first RUF RGT was based on the Porsche 996. It used the 3.6 litre engine from the GT3 as the base with the crankcase from the air-cooled 3.6 litre engines. The engine delivered 283kW (385bhp). The car itself ran on 18 inch RUF alloy wheels and the narrow body was optimised aerodynamically. The vehicle was fitted with a discrete but functional integrated roll cage.
In 2004 the story continued, this time based on the Porsche 997. Immediately recognisable by the screwed-on carbon composite fender extensions both front and rear. The power plant was a naturally aspirated 3.8 litre unit delivering 327kW (445bhp). A dry-sump oil system ensured sufficient lubrication even under tough racing conditions. A roll-cage was fitted as standard ensuring a high level of passive safety. The RGT was supplied with a chassis optimised for the race track and ran on 19 inch alloy wheels.
March 2010 and the time is right for RUF to announce the next generation of RGT, the RGT-8. This spectacular prototype vehicle is powered by a completely new RUF designed V8 engine with a 180° crankshaft "Flatcrank". Four valves arranged spherically together with multipoint fuel injection ensure optimal mixture conditions while the dry-sump system supplies the necessary lubrication. The lightweight engine has a very compact design, has a capacity of 4.5 litres arranged as a V8 and delivers 404kW (550bhp) @ 8500rpm and complements with a maximum torque of 500Nm @ 5400rpm. At all stages of the design process, compactness and weight saving were of priority, the result of which is a total engine weight of less than 200kg. A 6 speed gearbox with shortened gear shift movement transfers the power to the rear axle. To ensure the best adhesion characteristics, the RGT-8 is supplied with Michelin Pilot Sport Cup tires running on 19 inch RUF forged alloy wheels utilising a single central retaining nut. The powertrain is rounded off with sturdy ceramic brakes as standard for optimal braking.
The current Porsche 911 forms the basis for the RGT-8 chassis which is then further optimised with bodywork components from RUF. As always, an integrated roll-cage is supplied delivering increased chassis stability and passive safety. In addition, we are pleased to offer a Frère package which enhances the standard vehicle with special front fenders, nose and dashboard components. The styling was inspired by the 550 Coupé with which Paul Frère, the Belgian race driver, won the best of class at the 24 Hours of Le Mans in 1953.
The RUF RGT-8 production start is planned for 2011.
General specifications
Country of origin Germany
Numbers built N/A
Introduced 2011
Introduced at 2010 Geneva Motor Show
Engine
Configuration 90º V 8
Location Rear, longitudinally mounted
Construction aluminium block and head
Displacement 4.5 liter / 274.6 cu in
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Sequential Fuel Injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body unitary steel
Brakes ventilated carbon ceramic discs, all-round, ABS
Gearbox 6 speed Manual
Drive Rear wheel drive
Performance figures
Power 550 bhp / 410 KW @ 8500 rpm
Torque 500 Nm / 369 ft lbs @ 5400 rpm
BHP/Liter 122 bhp / liter
Source!
