Most of the time sulf works fine but sometimes when I start it wont start on the first sulf and when it does on the second it start very poorly (like low RPM) but after pressing paddle it works fine
Which paddle do you press to start?
sir ji please check for the clutch bearing it may need replacement. also please add extra 6mm black ground wire between battery negative and the engine. sometimes a weak battery ground connection to starter motor malfunction as well.
