I am here to ask you some questions. please help
1: My santro club front left tyre is slightly ahead of its position, near to bumper while the right tyres is okay. can it be adjusted and slide back a little by an alignment workshop. or its the job of a mechanic.
2: after how much KMs the tappet should be adjusted.
3: I have exchanged AC compressor with toyota duet, the AC mechanic has installed a metal bracket to support the new duet compressor, which now slightly lowered than the original, for that reason the AC belt has also changed and slightly bigger in diameter than the previous belt. now the problem is when it is raining the pulley attached to the compressor is producing weird noise for 2, 3 days for dry operation after rain is over, then it completely vanishes. is it the compressor pulley or bearing problem or the belt is lower near to the ground and soaking in rain water. please guide
4: how much it cost to install front break hubs with break caliper and without it. kabli or new? what you suggest.
5: there is a water protection metal cover behind break hubs mine one side is missing can it be found easily new or kabli? and cost if you know.
6: during raining my oil check light glow for some time and some time it goes off, while in normal weather it is completely okay. the oil pressure sender unit is of toyota car kabli one, not genuine santro one. Is it some wiring issue or oil pressure sender issue? in normal weather it is completely okay for even if it is not raining for several months.
Thanks for your valuable time.
