Check if you got the water or coolant in radiator.
If coolant then ask the previous owner when it was flushed, if not known then get it flushed and pour a fresh one. Recommendations will be pasted on under the bonet.
Radiator fan is direct or auto, if direct then this well tell you lot about how it was maintained.
Do check thermostat status, if it's there and working.
Brake oil change as well if history not known.
Thing is ask all the questions from previous owner to know the history of maintenance and then act accordingly.
Not sure if 2005 got the CatalyticConverter though.
Anyways, congrats on the purchase, very good fuel economy and softer suspension compared to other city's.
Most of the mechanics are high on Kabuli oil, so they will refer you everything starting with Kabuli. So either check it thoroughly or get the new OEM parts.
May it serve you well.
Ameen!
