nops, i am system administrator by profession and will be defending my MS level research on encrypted traffic after eid inshAllah,
acha ji back to the topic aise hai na k initially 100% of the AC power generated from a DC source will be fed to the motor, which will rotate the power house at high RPMs using a gear box, yahan tak sab theek hai, now when RPM are at sufficient level for the alternator change over kicks in just as in ur home computer UPS and cuts off the supply from DC source to the motor to the AC power being generated by the alternator hopefully without stalling the system, if ones computer did not stall on change over this should also not, well thats theory to be set right or wrong by experts in electrical and mechanical field. ok by now we have theoratically AC supply which will also charge the DC battery bank feed to the motor and to the home too.
lets c what you guys make of it
sir ji injector boring well ki motor chal rahe ho aur voltage up down tu motor kaam karna tu nahi chor dete na sir efficiency loose hote hai for couple of seconds only, as far as i know change over take 10ms for changing pins, but this what our fellows in eletrical field will comment, as i am not an expert in this matter.
main purpose of the topic is to discuss an idea which just popped in my mind, its not like i am taking up with this project or something, lets just discuss and let mechanical and electrical gurus come to this thread and see what they have to say about it, just that
