I am in kind of a fix with the float setting of my car's carburetor.
When I adjust it according to Factroy specs, fuel does not go into float chamber and when I increases the gap, the engine starts but does not idle. I cleaned the idle air passages in the top hat of the carb, bypassed the idle cutoff solenoid, cleaned and double checked the idle jet and its o ring, Also cleaned the primary venturi booster circuit. I am sure of every thing but the float setting and level of fuel in the float chamber.
What do you think should I increase the fuel level in the float chamber to resolve the idling issue.
Currently the fuel level is just above the main restriction jets and touches the base of power valve.
Plz guide...
