[quote="car.need.care, post:4317, topic:141239, full:true"]
Solved, took my carburetor to expert, he serviced it once again, he told me "pump main kachra agaya hai". In mean time i also replaced its fuel filter as old one have a lot of dirt inside.
Also waste some time to find air cleaner assembly rubber seals but unable to fine them. Finally took my old motor cycle tube cut it and make it in shape of a ring, put it in between lower and upper part of assembly. After couple of efforts I got success making it air tight. Now its sucking much more air from its mouth.
But still engine not stall if I put hand on its inlet, but much better than before.
[/quote]
Does it have some rubber seal where the air filter housing sits on carb mouth. If that is damaged/not present then it could be a issue there.
Otherwise the rubber seal that is on the outer side of the air filter housing cover must be damaged.
