@hassantahir2, @speedster_101, @tucknoloji, @shaidbokhari,
Last night I went to a trip but fall into a problem, after travelling 8 - 10 kms, car seems to gone out of fuel but I am sure there is 10 liter or more in tank and fuel gauge is near 40%. Car hesitates and engine stall, but after 2 or 3 min it starts again and then after half km again same happens. This happens 2 - 3 times. So i stop the car and start inspection.
Ignition and current seems good.
Check oil, no problem. Oil is coming into the head with good pressure.
Check water, its full. Temperature gauge is also at normal position so no heat up issue.
But when I accelerate water comes out from radiator as more as I accelerate like vomiting. I have newly built engine and there is less possibility of blown Gaskit. No symptoms of water and oil mixing not in radiator as well as on oil cap.
After all this, I converted my car to CNG and then come to home. On CNG car running smoothly.
Do you guys have any idea about this problem?
Why water is coming out of radiator? (I don't have thermostat installed yet)
For me the culprit is fuel pump which is not supplying enough fuel. Or maybe jet clogged (but why, I also have fuel filter and its good).
