What I know and have observed that When I refill full empty cylinder of CNG of 55kg which have capacity of almost 8kg gas on 210 Bar pressure which is excellent the Gas is not filled 8kg. Means 7.something gas. It means Cylinder has oil and that oil has covered the space of CNG. If your CNG Kit is oily then On CNG there is starting problem and your ride pic is relatively low.
You can easily remove the KIT oil by draining it. Exactly beneath the CNG kit there is a bolt which can easily be open by using "13 number pana" (tool name). After opening it start your ride on CNG. ALL OIL will be went out from CNG Kit. After a while Turn off the Engine and fix the Bolt again on Kit.
This is the safe way how you can easily remove the oil yourself from CNG Kit. For removing Oil from cylinder you may visit a reputed Total Pump who have CNG Kit Conversion facility. They can do this easily.
