Need some help here guys.
The threads of the in body nuts where the jumper rod gets tightened have stripped.
I was out to a nearby market, at a very slow pace, when I noticed my car swaying all over the road with no control over the steering.
Before I could think what could be wrong I started hearing a rattling sound from the front left side on every minor bump and also felt some thing at the clutch and brake pedal.
I stopped, examined and found one of the bolt on the left side of the jumper rod had fell off and the other one was on the verge of falling down.
I tried to tighten it, but it would not and later I found that the threads had stripped.
Called a friend and brought the car home.
Upon reaching home I discovered that the thread of the in body nut have stripped.
I tried screwing new bolts of the same size but in vain.
I consulted my mechanic who directed me to get a new nut welded over the current ones, to which I disagreed.
I was thinking to take it to a kharadia and get the threads re-made?
Will it do the job?
Will it be reliable and durable?
Also if the threads cannot be re-made then getting bolts with longer length and then tightening them with two more nuts from the top, which will act as check nuts?
Is this an option?
Will this be reliable?
Need suggestions about solving this issue as I have never encountered any such issue before.
Im attaching the images of the current situation of the car.
These are the nuts, highlighted in red that have stripped threads.
One of the bolt fell down and was lost, the other one is still there, tightened with the help of teflon tape.
This is the image taken from the bottom,
one in red is the front sire and the one in blue is the back side.
