@daniyal
Safety first! I think you should not drive in this situation until the problem is solved.
Im thinking of doing the same.
The accident last year was due to my laziness and negligence towards this issue.
Have you checked whether your front wheels locks first or the rear ones on hard braking. Because if your rear wheels locks only, then your car will spin on one side. Your car braking balance, the steering and the road tilt will decide the side the car will spin.
I tried checking this and almost everytime the car stopped normally and in time however it skidded two times on a similar patch of road (straight patch with no bend or inclination towards any side)
One time towards the right and one time towards left but this movement was very less and under control.
Also if one of your front wheels locks and the other keeps rolling, it will force the car to spin or drift on one side. But the side will remain same if the locked wheel is same every time. A stuck caliper pin can be reason but it will wear out that brake pad within weeks of normal use and you will notice black powder on the rim.
This is what exactly happened!
The car skidded towards right and when I went for brake service, the right side front brake pad was in a horrible condition and its edges were almost finished.
I'll open the wheels and then check the brake pads to determine their state.
12 years...! Either you don't brake a lot or your brake pads are rock solid (plus mirror-polished) so nor your pads wear out nor the rotor. I think the service manual says that when 2mm lining is left on the pads, you should replace it. Correct me please.
I actually meant the brake lining (the pipes) from which the brake fluid is pumped.
Any way to check their condition apart from general inspection?
