Hello!! Well Its About Creating Your OWN Grounding Kit For Your Ride...!!
Building Kit Duration:- 2-2.5 Hours
Installing Kit Duration:-1 Hour
Cost:- 1100-1200Rs "Wire+Thimbles(Lugs)"
Well Its Quiet A Useful Thing You Can Do To Your Car If You Really Need Smooth Idle And It Helps In Stabilizing And Maintain Equal Voltage Reading All Around Car....!!
In Market For 1200-2000....There Are Grounding Kits Available But I Am Not Satisfied With Them As They Just Give 3-5 Points To Attach Grounding With......The Provided Wire Is Also Quiet Thin And Runs In Parallel....!!
What I Do Is Get Better Quality Thick Wire......Running All Over Engine Bay......And In Serial......!! Having Less Resistance Than Parallel Ones....!!
Well Here Is The Provided Pictorial Of The Whole Thing...Who I Get Around And Make It.....!!
Get 15-16Ft Good Quality Wire...I Get This From Audio Store..Its BOSCHMANN Wire Used In Power AMP Wiring...!! Better The Wire..Better The Results...!
The Wire Quality...Pure Copper + Thick Enough...!!
I Cut Them Into My Desired Length As Needed....!! Here Comes Measurments....You Have To Take Your Car Measurements From Parts To Part To Make A Grounding Stronger By Connecting All Things Togeather...!! Here Is My Data..How I Measure Mine....Keep In Mind To Keep 2" Bigger When Measuring And Also Note Down Which Bolt Pattern To Follow On Which Wire....!!
Here's My Data To Help You Out
Battery(-) To Ignitor=18" (10mmx2)
Ignitor To Left Shock=10" (10mm)(12mm)
Ignitor To Gearbox =18" (10mm)(12mm)
Gearbox To Head Side =10" (12mmx2)
Head Side To Manifold=10" (12mm)(10mm)
Manifold To FPR =18" (10mmx2)....
FPR To Right Shock =12" (10mm)(12mm)
FPR To Chassis =7" (10mmx2)
Right Shock To Rgt Fender =12" (12mm)(10mm)
Fender To Engine Head=17" (10mm)(12mm)
Right Shock To Firewall=16" (12mm)(10mm)
You Can See Things Mentioned 1st Then Length Of Wire In Inches And In Last Bolt Pattern....You Will Need 2 Kind Of Lugs(Thimbles)..For 10mm or 12mm Bolt.....!! Do This Measurment Before Buying Wire So You Won't Waste Any Wire....!!
Cutted Wires
The Heat Shrink I Am Gonna Use....!! Quiet Useful....!!
Cut Them Into Pieces So Put Them Inn Wire Before Punching...Keep In Mind
It Hard To Strip These Wires From Plyer As It Will Break It...So Slowly And Gently Cut The Shield Using Sharp Cutter...Time Consuming Job
Stripped Wire...Ready To Be Punched...!!
Done...Its Done Using Plyer....!!If You Have Round Type Thimbles The You Need To Punch Them..!
If Possible....Give Them A Lil Solder On Sides To Make Them Strengthen...!! But Its Not Compulsary...Depends On Punching Of Wire...!!
Now Its Time To Heat Shrink The Ends......Done....!!
Taraaan....Finished Product...Directly Imported From U.S.A (h)
Closer Look Of
