23-11-08
Motive:- Cleaning And Inspecting Fuel Injectors And Replacing Fuel Filter......!!
So Here How It Goes Today In My Parking Garage Beneath My Uncle's Home.....!
12:00pm Sharp
Start Opening Throttle And Injectors Top Fitting Plate
Done....!!
Injectors Cleaning Setup We Do!!
Injectors Connected With +12V Supply To Make On And Off While Cleaning!!
12v 1.5A Supply We Use For This Purpose!!
Use This To On And Off Injectors...!!
Cutting Bottle For Making Bowl!!
Using NASA Carb Cleaner ....Best For This Job We Can Get
Here Is How It Looks During Cleaning....!!
Instant Build Pressure Pump......Which Won't Work So Good For This Job...!!
Injectors Cleaned For 1st Time And Keep Them For Some Time For 2nd Part Of Cleaning....!!
After Around 30mins....Starts Again......Testing It Using Different Methods...Can't Clean That Side Feeds Like We Can Do With Top Feeds In DIY....!! We Don't Have Place To Feed Them...!!
All 4 Cleaned And Ready To Installed.....!!
Its How 20v 295cc Side Feeds Looks Likes.....Notice The Silver Like Gauze On Side Of Injectors...Here It Gets Fuel From...Works As Quiet Nice Filter Too...Can Get Clogged That Easily...!!
Its How The Inside On Rail Looks Like....Have Some Dirt Particles So Clean Them Using Q-Tip 1st And Later Carb Cleaner Sprayed.!!
Another View
Fitting Them All Back Along With Throttle Fitting...!!
Throttle Being Fitted...!!
This Is How The Setup Mess Looks Like!!
Getting Ready For Another Job...!!!
Guess Whats This.....!! It Just Came Out Of Open Fuel Filter...!! When We Pressurize It
New Filter Getting Ready ....!!
Place Where Its Located...We Have To Open Quiet Alot Stuff To Reach This....!! Quiet Lengthy And Hard Job To Replace Fuel Filter On Places Like That...!!
Filter Fitted Being Fitted...!!
Fitting Of Banjo on Top Of Filter Which Leads To Fuel Rail!!
Being Fitted....!!
Well Its Quiet Time Consuming And Hard Part Of DIY.....!!
Results Are Not As We Are Expecting.........!!But Still We Have Done Some Good Work...Since Filter Gets Quiet Bad And Its Good We Replace It.....!! Problem
