Here We Start...
Day 6
8-11-07
As Finding Connection Session Is Almost Finished...So Its Time Now To Make ECU Connections...The Most Imp Part Of The Swap.....! As I Just Have Loom Cutted From Firewall And ECU Connectors....So I Have To Get Wires To Make Them Lengthy.....! Also I Need To Shop For Stuff Used In Making Joints....!
So Here I Go...!!
I Bought This Stuff...!!
List Of Stuff...
*Digital Multi-Meter...
*5 Color Heat Resistant Wire...
*2 Color Extra Thick Wire For Main Power Connections...!
*Heat Shrink Tube Of Different Sizes.. its 2.5mm 3mm 6mm and 8mm In Dia I think...!
*Goot Japanese Soldering Tip..
*Automatic Wire Stripper.. Believe me..It Makes Life Easy
*2 Different Kind OF Soldering Wire.
*Hard And Liquid Form Flux
*Solder Iron Stand....!
* 3 Kinds Of Tweezers
That Black Tubing Is Heat Shrink Shield I Am Gonna Use To Cover Joint Instead Of Taping Them..I Don't Wanna Be Nitto Tape Mechanic
Digital Multi-Meter...I Will Be Needing This For Diagnosing & To Check Sensors & Other Stuff...!!
Open Lock From Grip And Take Out All Connections For Joining..!
Finally After Hours Of Struggle..I Successfully Pull Them Out...Thats Other Thing I Wounded My Hands ..Thanx To Sharp Tweezer:$..Once I Know Trick..Its 2 Min Game Now
Taken Out...!!!
Have To Open ECM To Confirm Circuit #..Lots Of Capacitors And Transistors...!!
Here It Is...!! Confirmed
Thats All Of Day 6....!!
The Joining Session Is Coming Now Along With Method Of How I Did It
Regards
