Aoa,
I have a Suzuki Mehran 2003 Model and it has a problem that when I press the accelerator, the engine bogs down for a while and then jerks forward. I noticed it happens when the Ignition Timing is set on the 5-7 BTDC. I'm not using a timing gun so I might get it 2 3 degrees off but I still think I have it about right.
I remember the mechanic advanced the timing, without using any light and stuff and I didn't feel the engine bog down on acceleration.
Is the engine bog problem related to Ignition Timing? I'm thinking of advancing it more (to about 10 BTDC) and see if that removes the jerk. The only problem I saw was the car seemed to rev fast on idle (can't confirm cuz have no RPM meter).
I see everywhere that people say the timing for mehran should be 5 to 7 but I'm not sure why the engine bogs when set on those.
What are your thoughts on this?
