the you tube guy is using a steel hammer, thats bad, use a deadblow with a hard wood slug in between, it jerks the lock and you can release it by pulling the gear shift lever. The trick is not to be a caveman with a hammer, In two or three cases I have had to get under the car and disconnect the linkage and move the transmission out of park. Once its out of Park you can roll the car.
