Im a Beginner . I need A Little Help. Should I Buy a Rx8 Rotary Engine Or Swapped. And if swapped, then Which Engine Swapped and Why??
No you shouldn't buy a rx8. Since you're a beginner it's better to start at something simpler like an ek civic and then work your way up. After you've experienced this then you can but if you do get one I'd recommended getting one with the rotary as that is the heart and soul of the car. You'll find a lot of jz swapped ones but it's just not the same. However keep in mind rotary engines can be quite a drain on the wallet especially here in Pakistan where even authorized dealerships can't change cvt fluid in a Corolla.
stay away from any mazda with 4 wheels in Pakistan.
T3500 diesel truck YES
Thanks For the Advice Sir:)
Buy an Stock Rx8 if you really want to buy an Rear wheel drive vehicle
Thanks for advice. I had my eye on a mazda for a while, but now I'm not so sure
If it's going to be your first car than don't. Start with a simple car as i started with ek civic than after 3 years i bought 8 gen civic used it for 5 years and now i own a mark x. So build your way up and get some experience first
mazdas are good cars...but are difficult to maintain due to their rotary engines...
not all mazda have rotary - The piston engine mazda like axela, atenza etc. are fantastic - but are useless in Pakistan due to no spare parts, some new parts are required anytime you mess with the internals of the engine.
