hmm you are from karachi..
lets say you are in Liaqatabad daakhana area and all of a sudden you hear a blast and then gun fire, you (being sensible) would make every attempt to get yourself out of there. naturally you would run your car hard.
BUT
as your engine cooling system is using "Allah miyan ka universal coolant only" it has ate away the welch plugs, radiator seams and other bits too. This causes it to leak out while you are gunning it hard.
The leak causes the engine temp to spike which leaves you with two possible outcomes.
1 - your engine siezes due to heat - the goons get to you and either shoot you or set your car on fire.
2 - your engine runs but is internally cooked to oblivion causing you to drive slow while taking stone throws and gun fire - you limp your car home and prepare to spend 100K on the rebuild.
Not a good situation. lol
