^^ if its a bad map sensor then you have the following symtoms.
1- car wont start
2- car would start but would misfire alot and turn off when race is applied
if you are not facing any issue like this then you need to get your car tuned by a wideband sensor,you must be running rich due to:
1- more lph fuel pump then stock
2- more pressure in the fuel system then stock (from fpr)
3- maybe due to car being less advanced.
save some money and get a wideband and safc. and get it tuned from someone,you would experience a much more smoother ride,more power all over the powerband,and better fuel consumption where you need it.
