With the help of almunium foil take mark of the door bowl.
By using that foil mark the out line on back of clear skin sticker, We can use Laptop skins, or mobile protector skins for this purpose.
After cutting it to the required shape ,Peel it of and wet the sticky side of sticker as well as the targeted piece of handle bowl by soapy water.
Place it with care , adjust it, then try to squeze out water from mid to out wards in order toremove the soapy water in between sticker and surface.
Pursose is to avoid scratces in that area, as this area usually misused by ladies nails, children sharp toys and by finger rings.
Thanks for appresiation.
