Hey guys this is the new addition to my sound system:
1. Alpine mrv-f407:
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20kHz)
MRV-F407 (CH-1 – CH-4)
Per channel into 4 ohms ........................... 40W, 0.08% THD
Per channel into 2 ohms ............................ 50W, 0.3% THD
Bridged into 4 ohms ................................ 100W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20KHz)
Per channel into 4 ohms ........................... 60W, 0.08% THD
Per channel into 2 ohms ............................ 80W, 0.3% THD
Bridged into 4 ohms ................................ 160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 ohms ............................................ 120W
Bridged into 4 ohms .................................................. 320W
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
Slew factor .................................................. ...... Greater than 5
Damping factor
MRV-F407 ................................................ Greater than 100
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ....................................... Line in: 10k ohms<
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and Slope
MRV-F407 ............. 50 Hz to 400 Hz x 20, 12 dB per octave
Power Requirement .................. 11 – 16V DC Negative Ground
Dimensions (W x H x D)
MRV-F407 ............................... 260mm x 60mm x 330mm
(10-3/16" x 2-3/8" x 13")
Weight
MRV-F407 ........................................ 5.3 kg (11 lbs. 10 oz)
