Do the above mentioned check as mentioned by my fellow members and note that fuel evaporates and dries up very fast for it to be noticiable unless leak is bigger and continious.
As for the reason you do not smell fuel after certain amount of minutes due to inhaling and it becoming harder to recognize for you.
So check for leaks and make sure you do not have the idle on rich.
