Dear Solar energy experts
I need some guidance about a 5kw solar setup. Can someone please recommend which inverters and solar panels etc are recommended and their approximate cost?
Depends on what type of solar system you want.
Off-grid or on-grid (net-metering) or on-grid + off-grid (hybrid setup)
Many thanks. I am looking for on grid (net metering) system however hybrid setup would be an advantage if the cost difference isn't too high
for Net metering, contact any of ADEB approved vendors...and get quotations
http://lesco-bills.gov.pk.iis4001.shared-servers.com/lescoadmin/NetMetering/List_of_Approved_Vendor__Installers_Service_Providers_under_category_ARE_V2_latest.pdf
Many thanks for replying. Can anyone provide breakdown of the cost of similar setup?
On-grid 5kva would cost roughly in the range of 5-6lakh via a 3rd party vendor. For 5kva hybrid setup (3phase and net metering capable), the inverter will go up in price and you'll need a 48V battery bank as well
Thanks.
By ongrid setup do you mean without battery?
Yes, without battery. On-grid syncs with wapda's voltage to work. If wapda goes down, the solar system will shutdown as well (for safety reasons).
contact the turn key solution provider
met metering configuration not feasible for load under 10 KW
