AoA,
I have a 2017 Toyota Corolla Altis Grande (pre-facelift) and I’m facing an issue where the RPM drops when I switch on the headlights (low/high beam or fog lights) while driving. Interestingly enough, the RPM doesn’t drop when the AC is running at full speed without headlights and/or when idling.
I’ve already replaced LED bulbs with the original halogens, had a complete tuning done (fuel pump, injectors, throttle body, spark plugs cleaned/replaced, catalytic converter cleaned), and even installed a new car tracker. The alternator was tested by an electrician and confirmed to be working correctly (not undercharging or overcharging).
Despite this, my battery often ends up discharged, and I’ve gone through multiple weak batteries in less than a year. I also replaced the previous Phoenix 70L maintenance-free battery with a Daewoo DLS70, but the issue persists. I’d appreciate your advice.
Thanks
