Only 2 hours used, pin pack accessories.
Sony Handycam DCR-DVD608E
Manufacturer: Sony
Part Number: DCR-DVD608E
Specifications: Video input type: Camcorder ; Optical zoom: 40 x ; Media type: DVD-RW (8 cm) , DVD RW (8cm) , DVD-R (8cm) , DVD R DL (8cm)
Disc formats
Mini-DVD camcorders record high-quality MPEG-2 footage directly to a mini DVD-R or DVD-RAM and can deliver more than 500 lines of horizontal resolution, depending on camcorder quality. Recording directly to disc makes it convenient for playing directly in set-top players and for storage.
Best for: Trendsetter; home and vacation moviemaker; business videographer.
ADVANTAGES
DVD-Rs can be played in home DVD players
Easy searching and random access to video segments
Convenient and stable format for archiving
Selectable image-quality levels, including high-quality variable-bit-rate recording
Both video and still images are recorded on disc (instead of on a cassette and a memory card)
Exposure control
Every digital camcorder has a fully automatic mode that lets you simply point and shoot, but it's best to be able to adjust your exposure setting a little. Special shooting modes for capturing subjects lit by a spotlight or other specific sources can be helpful. For full control over exposure, you'll need a camera that lets you manually set both the aperture and the shutter speed. Advanced camcorders offer zebra stripes, which highlight overexposed areas with a striped pattern so that you can fine-tune exposure. Low-light performance is the Achilles' heel of many digital camcorders. Look for a model with a minimum lux rating of seven or lower. Many camcorders offer special low-light shooting modes, but they don't all work the same way. Some simply slow down the shutter speed so that you get full-color but impressionistic-looking footage. Others use an infrared emitter to capture greenish monochrome video in total darkness
