Sir its a very good AMP, one of the best.
2-channel car amplifier
200 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms)
500 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
low-pass crossover (50-300 Hz, 12 dB/octave)
variable bass boost (0-10 dB at 40 Hz)
MOSFET outputs and power supply
Tri-way capable (Tri-Way crossover required)
CEA-2006 compliant
speaker-level inputs with signal sensing for automatic turn-on
preamp inputs and outputs
fuse rating: 40A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
15-7/8"W x 2-1/4"H x 10-13/16"D
Best of luck
