Hello PakWheelers, I came with an idea which surprised me so much. So, I'm writing about Sound Dampening. I have been using Honda Civic'18 since a year now or so. But, I have noticed some noice from outside which actually drops my driving pleasure. So, I'm more interested in sound dampening for my car. I made some researches on it so I wanted to share it with you guys as well so I can get some useful pros and cons about this idea. I have found few sheets offering locally in Lahore but not much satisfied with them. So, I found economical and much better offers online (Aliexpress.com).
THEN, WHAT'S THE PROBLEM?
- If I ordered them so do I fall in any kind of heavy custom duties?
- How much sound and heat proofing I can expect?
- Does these sheets gets melt with time?
- Is it fine to chip these sheets under the engine hood?
- This will void my warranty?
So, I have seen a guy on Youtube installing a thin sheets under the doors. On that, he's actually applying some kind of a foamy sheet. After that, he again applied that thin sheet over that foamy overlay. After that, He covered the back of that plastic door with foamy sheet as well. So, Is this a good way to minimize the sound and heat?
And, as he used foamy sheets under the doors if water goes inside the doors and foam gets wet then it will rust the door from inside soon. Attaching few pictures as well so you can understand more easily. I'm writing here for you. You all guys are welcome to share your thoughts and opinions. Thank you!
