My Soundmagus mono amplifier is up for sale ,X-1502 is CLASS-D mono bass amplifier, condition is like brandnew ,
it can delivery up to 1500W rms at 1ohm load. It also can bridgable with another same amp
its rating are the following
1500W rms Class-D amplifier.
1 ohm load stable.
Double Side PCB and SMD components.
Adjustable Input level, LPF, Subsonic, bass boost function.
Advanced short circuit, overload, over heat and low voltage protection.
Easy bridgeable with same amplifier.
Heavy duty terminals.
Optional remote controller.
X1502 Specifications
RMS Power at 14.4V (into 1 ohm 50Hz THD+N < 2.5%)
1500 Watt
RMS Power at 14.4V (into 2 ohm 50Hz THD+N < 2%)
950 Watt
RMS Power at 14.4V (into 4 ohm 50Hz THD+N < 1.6%)
600 Watt
LPF frequency
40~180Hz Adjustable
Subsonic switch
Yes
Subsonic frequency
10~50Hz
Frequency Response
10Hz--180Hz
Bassboost frequency
30-80Hz
Bassboost gain
0~12dB
Low Pass Filter
24dB/Oct
SUBSONIC Filter
12dB/Oct
Operating voltage
DC10V--16V
Remote control
Optional
High-grade Nickel-plated, heavy duty terminal block type connectors
Yes
protection
Short circuit, Overload, over Thermal
Dimensions (HxWxD)
53mm x 228mm x376mm
Contact me at 0322-2050150
