The product I used was Ultra guage.
Ehtesham bhai yeh kis liye ha?
This is one scanner with display.This can show/clear engine error codes.As well as it shows you engine parameters on run time.
Thank you , i was thinking to debage mine for a while now, did you clean all residue with the plastic pryer only?
Will remove all civic , 1.8 oriel badges , will give it ultra clean look .parking the car in sun for 20 mins and dental floss should do the work
Initially with plastic pryer, and then uses some rubbing compound for surface cleaning..To remove residue, it can be cleaned 100% with plastic pryer or with your nail.And I the last, for best results heat it a bit. Sun is enough
Yes dental floss will work best
How’s the exhaust note?
What parameter does it display. Is this a universal guage and can be installed in any car? I intend to install this type of guage in my corolla 2008 as its an old car and i need to keep a check and balance on the parameters
Very good
It shows everything that an ELM327 does
Thise badges look more beautiful than Si badge
May be pkdm civic looks better than Si in ones opinion.It can be ones choice.
I likeUSDM Civic Si 4 door Sedan2018 model.So it's a the transformation
Have you Considered this front look for you Civic. Before starting Project?
Yes, I didI didn't like the bug chrome bling bling on the bumpers
No Definately your Modified civic looks more attractive and beautiful than PKDM Civic
Its just the red colour not looking good in my openion
Everyone has their own choise
Plus, the one you are referring doesn't look sportier to me
Look at this. Of course personal preference.
And this ..
