dear the spark plug gap depends upon the spark plug itself. both DENSO and NGK sparks plugs are standard for Suzuki engines.
for example for DENSO is you use plug having U11 then gap should be 1.1 mm, otherwise its 0.8 MM.
if manual suggest bpr6es then you can use plugs having heat range value as 6.
i guess BKR 6 EGP will do fine, purchase brand new from reputed parts shop and do not adjust the GAP as it is pre gapped from factory, make sure that you donot drop it on hard surface to alter the gap.
