@vaqas1,
One thing is that about 2days modern spark plugs orignaly made for modern engines, 2days engines works better on CNG type fuel then older engines cause of better intake induction system like EFI 4valve/cyl & distributor less ignition, in distributor ignition quality of point & setting is very important, check your car to good mechanic hope fully u'll see better results.
@khahsan,
In Baleno install Denso's K20TR-11 or Bosch FR78X no need to use Iridium plugs.
@allie,
For Alto VXR petrol,install Denso W16EXU or for running on CNG Bosch WR78.
@antiflag,
There's two type of engines in Vitz, in "1KR-FE" Denso # SK20HR-11 or Denso's Iridium IKH20 & in Bosch Platinum FR6MPP332 & in engine "1SZ-FE" Bosch 4tip FR78X is perfect, no 2 or 4 tip plugs in platinum or Iridium avilable 2days market if avail then it would be very expensive, what is your's car engine? engine model code like above mention pls specify me.
@Redbull_ar,
You are most welcome.
