Hello Everyone.Just want to know when to change the spark plugs?I mean should I change it in 6-8 months time or it depends on kms done ?
I have heard that if spark plugs run out then the car uses more fuel ?? Is this true ?
When the car doesnt start :)....kidding
what car do u have by the way
more imprtantly than changing your plugs you should get them out , have then cleaned and make sure you have the correct plug gap.
Also a plug (colour & depoists) can tell you alot about the engines condition.
@Altima
There is an option on PW which, in simple words is called Search, please try to use it whenever u've Questions!
[highlight]When To Change Spark Plugs
https://www.pakwheels.com/forumreply_az_TopicID!11015~ForumID!10~pw.html
How To Read Spark Plug Codes
https://www.pakwheels.com/forumreply_az_TopicID!11258~ForumID!10~pw.html
Everything About Spark PLugs
https://www.pakwheels.com/forumreply_az_TopicID!27434~ForumID!10~pw.html[/highlight]
