Which speakers should i buy under 10k for my cultus 2011? Currently i have pioneer TS-A6965 V2 installed. Budget is 10k
anything wrong with your speakers?
High volume pai awaz phatnai lag gai hai.
that is called clipping, and is not problem of speaker.
at high volume voice gets distorted.
are you using an amplifier?
Nope
you will need to use a good quality amplifier to get more sound.
ideally you should not have to turn the knob more than 50%.
if you turn it all the way, you get sound clipping, and no matter what speaker you buy you will face phatti hui awaz.
Speakers are useless without Amplifier keep that in mind. Running them on low or under power may lead to coil damage over time so be careful with that. The one you using are of 60w continuous handling power the headunit can't produce morethan 22w RMS. If yours 6965 v2 were original then it shouldn't go bad that mich quickly. How long you have been using them? I have recently spent 26k on speaker, Amplifier I did one time investment of Amplifier Don't want to waste money on chinese I bought Pioneer 1000 watt amp that can produce 60w RMS @4ohm to 4 channels. My main concer was Amplifier that costed me 15500 it a bridgeable amp model is A6704. Speaker I bought are pioneer 6970f for 7000 and the one I like were for 15500 and model was 6975 v3 they didn't came in my budget. 6970f still sounds great and because I have CNG installed so I got speaker box made that's not much room for performance that it should have in spacious place like without CNG or car having trunk.
My Next Target is to Install components In front doors I know there is less space But I will mount them in Adapters will order them from Aliexpress then sound quality will be great and will be demanding. I have planned each and everything like door rattling and sound proofing but only thing is restricting me is my budget I atleast need 16000 to thing go smoothly. Cause components are hell expensive I have choose pioneers they going to cost me 10 to 11k.
