Plugs preform better when coupled with high performance ignition systems or uprated spark generation. Its a useless expense.
Stick to stock. I'm pasting an NGK Spark Plug Chart for reference.
The following is what you'll see inscribed on the elctrode coating(white portion) on your SP. Heat ranges and operating temperatures are descrined in detail.
B CPR 6 E S -11
First letter from example (B):
Thread Diameter
A 18mm
B 14mm
C 10mm
D 12mm
J 12mm
Second box from example (C, P, R):
Letter Construction
C Hex size five eighth"
K 5 over 8" projected tip (ISO)
M Compact type
P Projected insulator type
R Resistor type
U Surface or semi-surface discharge type
Z Inductive resistor
Third box from example (6):
Heat Range
2 Hot - 6 Cold
Fourth box from example (E):
Letter Thread Reach
E 19mm (Three fourth")
F Tapered seat
H 12.7mm (Half")
L 11.2mm (seven sixteenth")
No symbol:
18mm?=12mm reach
14mm?=9.5mm (three eigth") reach
Fifth box from example (S):
Letter Firing End Construction
A Special design
B Special design for Honda CVCC
C Low angle ground electrode
G Fine wire nickel alloy center electrode
GV Gold-palladium center electrode
Special construction of V-type
Racing use
H Partial thread
K 2 ground electrodes for Toyota,BMW,
L Half heat range
LM Compact type for lawn mower
M 2 ground electrodes for Mazda rotary engine
N Special side electrode
P Premium platinum
Q 4 ground electrodes
R Special ground electrode
S Standard 2.6mm? center electrode
T 3 ground electrode
U Semi-surface discharge
V Fine wire gold-palladium center electrode
VX High performance platinum
W Tungsten electrode
X Booster gap
Y V-grooved center electrode
Z Thick 2.9mm? center electrode
Sixth box from example (-11):
Number Gap
-8 0.8mm (0.032")
-9 0.9mm (0.036")
-10 1.0mm (0.040")
-11 1.1mm (0.044")
-13 1.3mm (0.050")
-14 1.4mm (0.055")
-15 1.5mm (0.060")
-20 2.1mm (0.080")
Note that not all 6 fields will always be used, such as in BKR6EY.A hot-cold plug designates a plugs ability to retain or dissapate combustion heat! Lower grade fuel requires hootr plugs while high grade work equally well with both depending upon application.
