Is good to use Automatic voltage regulator(stabilizer) for an Appliance at home when a generator set is on View All
when a generator set use at home is supplying power to a building, precisely in a room that has automatic voltage regulator ( stabilizer) used in stabilizing an appliance. is it good to connect the stabilizer directly to the socket outlet or to connect the appliance itself directly to the socket outlet since the out put power from the generator is 220v.
